Текущее время: 14 июн 2025, 19:56
 Заголовок сообщения: Новинки от компании Dune HD
Сообщение Добавлено: 06 сен 2012, 13:33
TV-103D, TV203D, TV-403D Specifications
Processor: Sigma Designs SMP8673
RAM: 256 MB
Flash memory: 256 MB, expandable with a HDD partition, USB flash drive (2GB recommended)
Media sources: external HDD (USB), external optical drive (USB), USB devices (USB flash drive,
USB card reader, etc), PC and NAS in local network (SMB, NFS, UPnP, HTTP), other Internet and
local network media sources (HTTP multicast UDP/RTP), premium streaming video services are
fully supported
Web Browser: Opera, WebKit or NetFront (ACCESS)
Widgets support: when using NetFront browser
DLNA: Full DLNA (1.5 or 2.0) standard support
Adobe Flash: 3.1 (Lite, standalone)
DRM options: Microsoft DRM10 and PlayReady, Verimatrix, Secure Media. Additional DRM’s
available by request
Video codecs: MPEG2, MPEG4, XVID, WMV9, VCl, H.264; support for very high bitrate video (up
to 50 MBit/s and higher)
Video file formats: MKV MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV MP4, QT ASF WMV DVD-ISO,
VIDEO_TS
Video output modes: wide range of supported output resolutions (up to 1080p) and framerates
(including 23.976p, 24p, PAL, NTSC)
Video output framerate: automatic (according to the played content) and manual
Audio codecs: AC3 (Dolby Digital), MPEG, AAC, LPCM, WMA, WMAPro, FLAG multichannel FLAG
Ogg/Vorbis; support for very high quality audio (up to 192 kHz / 24-bit)
Audio file formats: MP3, MPA, M4A, WMA, FLAC, APE (Monkey’s Audio), Ogg/Vorbis, WAV AC3,
AAC
Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV external),
VobSub (MP4, MKV external SUB/IDX), PGS (TS, MKV)
Picture file formats: JPEG, PNG, BMP GIF
Playlist file formats: M3U, PLS
Photo viewer functions: slideshow, transition effects, picture rotation, zoom, browse playlist,
repeat, shuffle
Audio playback functions: browse playlist, repeat, shuffle, ID3 tags, plasma TV burn-in prevention
Filesystems: FAT! 6/FAT32 (read-write), EXT2/EXT3 (read-write), NTFS (read-write)
Ethernet: 10/100 Mbit/s
Wi-Fi: Internal Wi-Fi (b/g/n) module (depending on modification)
Dune Network Playback Accelerator: special optimizations ensuring best-in-class network
playback performance for the Sigma Designs 864x/865x/867x platform and enabling smooth
playback of any supported kind of media content via any network protocol (including NFS and
SMB) even in 100 Mbit/s Ethernet networks.
There is no TV-303D, the TV-403D is going to be the largest unit in the TV series and now offers a 3.5″ hard drive bay rather than the 2.5″ bay offered on the TV-301
 Заголовок сообщения: Re: Новинки от компании Dune HD
Сообщение Добавлено: 06 сен 2012, 13:35
TV-201 Set Top Box
Also on display was the STB version of the TV-201 – the Dual DVB-S2 enhanced TV-201S2. It was also sporting a new interface that I was advised would be rolled out to all units in a future update
Сообщение Добавлено: 06 сен 2012, 13:39
Dune HD Base 4.0 3D
The BASE3D was also on display but I didnt see a working demo of the unit. This 3D unit houses a 3.5″ hot swap bay behind a flap and will play full 3D files.
Modular Entertainment Station Features
3D Video Format Support: Decodes wide variety of 3D Video formats, including MVC, SBS, Top/Bottom and RealD 3D.
HDD Player: Plays content from any HDD (NAS, USB, eSATA, Dune HDD Expansion Chassis)
Network Player: Connect Dune HD Pro to a local network and play content directly from PC or NAS via UPnP SMB. or NFS.
MKV Player: Playback HD and SD video in MKV containers and other modern video file formats, including top quality HD video with very high bit-rates > 50Mbp/s.
USB Ports: Conveniently connect HDDs, USB flash drives, USB card readers and other USB storage devices without a USB hub.
HDD Rack Option with Hot Swap Function: Easily and quickly insert and exchange internal 3.5″ SATA HDDs for nearly unlimited storage capacity expansion.
HDMI 1.4: Ensures broad compatibility to the very latest 3D TV’s, displays and projectors
Full Range of A/V Connectors: S/PDIF Optical Audio, Analog Stereo Audio, HDMI, Component Video, Composite Video.
High-Quality Music Playback: Plays very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAG Monkey’s Audio APE, WAV/PCM, DTS, etc).
Playlist Support: Build playlists from folders, use your own play lists with repeat and shuffle functions
Video Output Flexibility: Output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSQ.
Video Up-Scaling: High quality up-scaling of DVD and any other SD video content to Full HD (1080p) or other HD resolutions.
File Browser: Convenient file browser with powerful file management (copy, move, delete, rename, organize, sort).
Extra Functions
External NAS Support: Access files on any external storage devices (HDD, optical drive, etc) attached to the player from the local network (using SMB or FTP).
Customizable User Interface: Work with media collections using cover art and icon browsing (supports Full HD graphics).
Flash Applications: Extend player functionality with FlashLite applications.
Internet Radio: Playback and record various Internet radio stations.
IPTV: Playback and record IPTV streams (multicast UDP/RTP) from Internet providers (check availability of multicast UDP/RTP streams with your Internet provider).
Internet Browsing: View Internet web sites on your TV using the built-in web browser.
This model should be available in stores across Europe by the end of October
Сообщение Добавлено: 06 сен 2012, 13:42
Dune HD Max 2.0 3D
As well as the BASE3d, Dune were also displaying the new Max3D. Specifications of the machine are below but the actual processor used and as its actual release date are still under wraps. Significantly in the specs below they mention will be available in Black or Silver. Only the black model was in display at IFA. Other than the ill-fated HD Pro this is the only model to come in anything other than black.
3D Video Format Support: Decodes wide variety of 3D Video formats, including MVC, Blu-ray 3D and RealD 3D.
Audio: Supports the highest quality audio performance with Dolby True HD, DTS HD Master Audio, LPCM, FLAG
Blu-ray (3D) and DVD Player Option: Play Blu-ray and DVD discs (plus Audio CD and data discs with video, music and photo files).
Network Player: Connect Dune HD Pro to a local network and play content directly from PC or NAS via UPnPSMB, or NFS.
HDMI 1.4: Ensures broad compatibility to the very latest 3D TV’s, displays and projectors.
Full Range of A/V Connectors: S/PDIF Optical Audio, Analog Stereo Audio, Multiple HDMI’s (input and output), Component Video, Composite Video.
Extended Support for Dolby True HD and DTS HD Master Audio: Output bit-stream (up to 7.1 channels) or decode (up to 7.1 channels) for maximum flexibility when connecting audio equipment, and for extended support of advanced playback features (such as Picture-in-Picture).
Playlist Support: Build playlists from folders, use your own play lists with repeat and shuffle functions.
Video Output Flexibility: Output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSC).
Available in Two Colors: black and silver.
Extra Functions
Сообщение Добавлено: 06 сен 2012, 13:46
Dune HD Connect
finally we come to the diminutive HD Connect, which Dune claim as the Worl’d smallest Full HD Media player. In the format of a HDMI dongle with 3D video and 3D graphics support, built-in WiFi, Bluetooth, options for Z-Wave and DVB Tuners.
Processor: Sigma Designs SMP8672
RAM: 512MB
flash Memory: 4 GB
Media sources: microSD card, external HDD (USB), external optical drive (USB) USB devices (USB Flash drive USB card reader, etc), PC and NAS in local network (SMB. NFS, UPnP. H11P), other Internet and local network media sources (HTTP, multicast UDP/RTP). premium streaming video services are fully supported
A/V interfaces: HDMI 1.4 output; MHL output; analogue A/V output via micro USB connector (cable adapter required)
Hardware 3D Graphics acceleration: OpenGL and WebGL
DNLA: Full DLNA (1.5 or 2.0) standard support
DRM options: Microsoft DRM10 and PlayReady. Verimatrix, Secure Media. Additional DRM’s available by request
Video codecs: MPEG2, MPEG4, XVID. WMV9, VC1, H.264; support for very high bitrate video (Up to 50 MBit/s and higher)
Video file formats: MKV, MPEG-TS, MPEG-PS. M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, DVD-ISO. VIDEO.TS
3D Video Support: MVC, Side-by-side, Top/Bottom
Video output modes: wide range of supported output resolutions (up to 1080p) and framerates (including 23.976p, 24p, PAL. NTSC)
Audio codecs: AC3 (Dolby Digital), MPEG, AAC, LPCM, WMA, WMAPro, FLAC, multichannel FLAC, Ogg/Vorbis; support for very high quality audio (up to 192 kHz / 24-bit)
Audio file formats: MP3, MPA, M4A, WMA, FLAC. APE (Monkey’s Audio), Ogg/Vorbis, WAV, AC3, AAC
Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VOBSub (MP4, MKV, external SUB/IDX). PGS (TS, MKV)
Picture file formats: JPEG, PNG, BMP, GIF
Photo viewer functions: slideshow, transition effects, picture rotation, zoom, browse playlist, repeat shuffle
Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3 (read-write), NTFS (read-write)
WI-FI: Internal Wi-Fi (b/g/n) + Bluetooth module
DVB: optional cable or terrestrial DVB tuner
RF Remote Control Unit: bundled
Home Automation: internal Z-Wave module (optional)
Сообщение Добавлено: 06 сен 2012, 13:47
IFA 2012 - Dune HD Coverage:
TV-102
TV-103D
TV-202
TV-203D
TV-402
TV-403D
Base 3D
Max 3D
Pro
Connect
Сообщение Добавлено: 20 сен 2012, 14:20
Девайсы для просмотра ТВ становятся все миниатюрней
Сообщение Добавлено: 20 сен 2012, 14:52
Когда в продаже и по чём?
Сообщение Добавлено: 20 сен 2012, 16:50
К концу года обещают....
Сообщение Добавлено: 18 янв 2013, 16:01
скоро скоро ...
Сообщение Добавлено: 18 янв 2013, 16:07
и как же мне знаком этот столик...
Сообщение Добавлено: 18 янв 2013, 16:14
а с этого места подробнее... плиз :)
Сообщение Добавлено: 18 янв 2013, 16:19
ну ок... если просите, именно на этом столике прошивалась моя дюна :D :D :D :D :D
Сообщение Добавлено: 18 янв 2013, 16:25
мой это столик ..
Дюны получены для тестов ..
собственно, скоро будут в продаже в Украине
Сообщение Добавлено: 18 янв 2013, 16:30
мой это столик ..
Отличный столик для дюн :wink:
А чего ж TV-201S2 http://tech-inform24.ru/multimedia/dune ... nerom.html не взял для тестов?
Сообщение Добавлено: 18 янв 2013, 16:37
Места у журнале и так нет ...
Все забито под тесты.
очереди стоят из желающих протестироваться . .если честно ..
потому, взяли 2 образца на пробу .. а там посмотрим .
у нас уже лежат готовые тесты эпплТВ, року.. ну что бы электорат понимал, что оно вообще такое ???
Сообщение Добавлено: 18 янв 2013, 16:48
Поздравляю :) тогда пора проводить АУКЦИОН на вакантное место под тесты :wink:
Оно конечно не плохо, что электорат ознакомится с новинками, но вот за какие фантики он это сможет купить... :?:
Пусть читает... и мечтает :wink:
Сообщение Добавлено: 08 апр 2013, 21:01
Страна: Rwanda (rw)
Обзор Dune HD TV-303D с поддержкой 3D
Сообщение Добавлено: 08 апр 2013, 21:14
Отличный обзор от Gagadget. Dune HD Base 3D: дорогая дека для современного человека
И ваш покорный слуга с дощечкой "Выбор редакции"
Сообщение Добавлено: 08 апр 2013, 22:26
Саша, это всё кАрАсиво, НО во многих случаях НЕ актуально. Единственное, что требовалось от Dune это TV-201S2. А его НЕТ, и не предвидится.
Сообщение Добавлено: 09 апр 2013, 05:26
В том году ждал 9 месяцев , устал - и купил Amiko ! :D
Сообщение Добавлено: 09 апр 2013, 09:54
Myroslav поведайте пожалуйста инфу... так когда же появится в продаже TV-201S2?
Сообщение Добавлено: 17 апр 2013, 06:44
Страна: Rwanda (rw)
Еще обзорчик http://www.thg.ru/video/obzor_dune_hd_b ... index.html
Сообщение Добавлено: 26 дек 2015, 00:13
Dune HD Solo 4K – новый медиаплеер с поддержкой HEVC и 4K
Dune HD Solo 4K – новый компактный и мощный медиаплеер, доступное решение, поддерживающее воспроизведение 4K/Ultra HD видео и видеокодек HEVC (H.265).
Модель способна воспроизводить в наилучшем качестве практически любой контент – как из Интернета, так и из других источников. А встроенный тюнер DVB-T/T2 даёт возможность смотреть программы эфирного цифрового телевидения.
Медиаплеер Dune HD Solo 4K построен на базе процессора SMP8758 – первого и пока единственного в своём роде процессора Hi-End класса от компании Sigma Designs, который поддерживает обработку с 4K/Ultra HD видео. Мощность нового медиапроцессора на базе ARM в целых 4 раза выше мощности процессоров, которые использовались в предыдущих моделях медиа-устройств Dune HD.
Новая модель может воспроизводить 4K-контент, а также масштабировать любой иной контент в Full HD и 4K. Качество картинки гарантирует использование видеопроцессора профессионального класса VXP.
Плеер поддерживает видеокодек HEVC и новый стандарт, использующих 10 бит на один цветовой компонент (вместо привычных 8 бит). Это даёт возможность воспроизводить на экране более миллиарда цветов, что в 64 раза выше доступных ранее показателей.
dune-shop
